pivaino
Hi, both on the net and on the forum I looked for the solution to my problem in vain.
can you tell me why from the autocad versions since 2011 then the function measures --> more points does not work me? ?
in practice selected the distance functionality, click on the first point, then right click and click on "plus points", select the second point and finish the command giving me the measure.
is it an autocad problem from the 2011 version onwards (because with v. 2010 it works) or do I have any bad set preference?
I hope you can help me.
thanks in advance
thanks in advance
