Andrea_Elett_90
Good day to all,
I have an architectural file designed in meters (ltscale=1,1 unit=1 meter), when I insert this design as xref in my I can not correctly view the detachment of the retinals and lines, (note, my design is in centimeters, ltscale=1, 1 unit= 1 centimeter).
I tried to change the value of ltscale to correctly view the restraints of the retini and the lines, but in doing so I should change the type of scale of my lines, which I do not want and cannot do.
Can you tell me if there's a command to insert my xref without the scale of my design affecting the braces and lines? ? ?
Can I solve it in another way? ? ?
(I have already tried with ltscale but I want to keep it to 1 on my design, I tried with psltscale but it does not hit anything and I tried also with the teilmode command, but sincerely I did not understand how to use it. )
Thank you! ! !
Thank you! ! !
