mauritius
Does anyone know how I can prevent the ribs of a section from being sampled? use solidworks 2007
using to model her command nervation (always in the menu Functions), so that the table recognizes it and when you do the section opens the window to decide its exclusion.Does anyone know how I can prevent the ribs of a section from being sampled? use solidworks 2007
Frankly I didn't understand your request, can you explain yourself better?Bye to all,
reading the thread came a curiosity:
ribs are managed at part level as a bolean sum to the body that generates them.
with the introduction of the structural members I thought I could also ball the ribbs, quote them in the table itself and above all handle them as we do with the body in modeling.
How are you doing?
dancer
I don't know (I don't understand?) and honestly I don't. in a "normal" part when you make ribbing becomes a multibody part; the bodies then you can save them externally to the "father file" but they will remain "without history".ribs are managed at part level as a bolean sum to the body that generates them.
in welded with structural members there is another special command for ribs that become structural members. so you can safely post them and put them in separate cut as all other elements.with the introduction of the structural members I thought I could also ball the ribbs, quote them in the table itself and above all handle them as we do with the body in modeling.
How are you doing?
dancer
It is true, I understood wrong and explained even worse:biggrin: (and also wrong); the ribbing in the part as you say you become unique body. This is because (I believe) is understood by the system as a real rib, that is, for example, obtained in fusions and therefore absolutely unique body. and rightly gives you the opportunity to exclude the section on the table as standard.You're right. I've been a little cryptic. . .
premise
sw2009 and side files
I posted an example that shows better what I meant.
the ribbs( gusset) in the structural elements can be done (only flat faces) and then treated as individual bodies; in the cutting disc are listed and usable.
classical ribbs are not single bodies but only one (bolean sum) with the part that generated it (among other things one body admitted); Therefore you cannot move them and reposition them sen not after having divided them. Last: you can't make the single special table for carpentry preparation.
At this point I asked if the approach could be different.
Thank you for your patience
dancer
the welding environment is very high in modeling, but sometimes obliges to really strange procedures. the environment together allows for greater flexibility, sometimes at the expense of times.thank you all,
I also thought of the axieme but then the cut list would be heterogeneous because it was reported on several side files.
I think the ribbs function is intimate with the part on which it leans and therefore in the logic of the developers should not be released: evolution could be the management of ribs as loose bodies.
"...but maybe the function was born for molds and therefore monolithic bodies. "
In any case, my opinion on the introduction of the welding environment is more than positive and never poses unresolvable criticalities.
thanks to all
dancer
