problem sheet format in print phase
  • Thread starter Thread starter Piron88
Piron88
Good morning to all
I can't understand why, since I recently installed autocad 2014, when I execute the press command, select the print area with the window, and imposed the a4 format of my printer, this, in the custom settings, instead of using the a4, format uses the "free size 210x297mm" format, modifying me accordingly also orientation of the sheet and location of the center. so forcing me to every print different from the layout I have to do in a4 format, to have to go to change the custom settings.
How do I proceed to adjust the printing setting so that whenever I choose the a4 format I am actually printed in a4?
p.s. this does not happen with a3 format
