problem symbol diameter placed at the table
  • Thread starter Thread starter Max-C
Max-C
Good morning,
I don't know why but since I installed the 2015 version sp4 in the table, I write the diameter code instead of making the symbol.
Does anyone know how I can solve this?
I discovered that it is probably the damaged gtol.sym file. recommend to replace it with another machine but same version.
Could someone kindly pass me his gtol.sym file? having only one pc with solidworks 2015 I don't have the chance to get another...
Good morning
I resume this discussion not to open another one, I have the same problem as max-c
the diameter symbol no longer appears in both table and part.
I updated yesterday the version of solidworks at 2022 sp.5.0
Could someone help me by sending me the gtol file or indicate how to fix the problem?
problem solved
I contacted the assistance, which remotely solved the problem, in practice updating the version of solidworks, had not changed the paths of the files, which pointed to the folders of the old version. with the change of paths, the problem has been solved
