DavidNX
Good morning to all, I looked around but an answer to my problem I can't find it.
I have a 3d set composed of n°6 components.
These 6 components are bound in the assemblies on csys whose position with respect to origin is regulated by some expressions.
inside the axieme I use the linked-body command to be able to combine the 6 components in a single solid and perform all the processes that the finished model needs. (it is multi-stage hydraulic machines and each hydraulic component must be modeled separately and then be combined into a single body)
until some time ago I never had any problems in changing the position of csys through an expression defined by the user, as it never gave me problems increasing or decreasing the number of stages of the machine that I'm modeling through the use of the key-array command, varying the value of long x copies always through a variable in the expression list.
from a few days though, working on a new machine, I have problems updating the model, after I go to vary the value of x-ray copies.
to explain to you, it seems that unigraphics first upgrades the axieme feature tree, but skips everything about linked body, csys position regulated by expressions etc, with the result that crashes the model.
the absurd thing is that, finished this "first" update, noug starts with a second update, in which everything is updated regarding linked body and related key arrays.
Therefore, during the "first" update, I get out many messages of
error related to features that jump, but at the end of the whole procedure, then even after the "second update", in the tree there is no trace of error, and also visually I see to video the model that is updated in 2 sessions, and not all at the same time as so far it happened to me.
I clarify that those I call "first" and "second" update happen in rapid succession. . at the end of the first, the dialogue bar presents the written: done updating feature, but immediately automatically part the second update, which in turn at the end shows the same written done updating feature.
I apologize if I have not explained very well, I remain waiting for your help and available for any clarification,
David
David
