tmeinventor
Hello everyone
use inventor 2010
I have this problem, in a design I need to make a split view but also the interrupted command
I try to explain in detail
In practice I have a beam where I have to "shoulder" a plate to show the asola...but the beam is very long and for the scale and format that they have imposed me to hold it forces me to make an interrupt
the problem that I detect is that if I design the sketch for the split view also resulting from the projection of a edge of the plate, as soon as I interrupt and the beam shortens you do not take behind the sketch for the split view... is there a way to overcome the problem?
one I found is to try to reposition to the eye the sketch by moving it to the area where, hypothetically the plate is placed on the beam not interrupted... but you don't seem to function perfectly
This situation unfortunately will turn back on other tables
I hope in your suggestion
Thank you
use inventor 2010
Thank you
