problem view together
  • Thread starter Thread starter tanticapelli
tanticapelli
hello to all and good year!
start 2018 exasperating with a question related to a visualization problem in ambiene together "big axioms" modes with "shaded with edges" display.
Sometimes, while I enter and exit from the modality part to drill, it happens that the graphic window takes on an aspect like what you see in the screenshot with which it is almost impossible to work as the edges are no longer represented with the correct display order.
also doing ctrl+q, ctrl+b, and visulizza-->regenerates nothing and are obliged at least to close and reopen the axieme, if not even the session of solidworks.
Does it happen to you?
thanks, as always
so many hairs
Happy New Year to all boys!
It happened to me sometimes, even worse than what you see, in the sense that to me it became a model with autocad lines. So I guarantee you're "normal" :)
is it not the transparency of changing parts in the environment together?
If that's the one system options>visualisation>transparency together for contextual change
Yes, however, transparency persists even after you came out of the change part.. .
before upgrading, backup the previous driver or restore the system. not trusting is always better
