vidus
Good morning to all,
I created a family gates, the purpose was to have a door that could be seen open in the plant and in the prospect/section it would be seen closed. to achieve this effect I have placed in the family two doors: an open (give it in the visibility options the popping up on the show in the plant) and a second closed (putting in the visibility options the front/back and right/left).
the thing seems to work but only partially; I'll explain.
I always see the door open.
in section I see the door closed but only if the view is perpendicular or parallel to the door, i.e. if I am actually seeing it in front/back or right/left. The problem is when I see a shortcut door... In this case I will see both doors of the doors. How to solve this inconvenience?
this also happens in 3d.
Thanks for the answers.
