problem welding inventor 2010 in rendering
  • Thread starter Thread starter ValvMax
ValvMax
Hello, everyone. .
as from title now I stand in front of another osctacle...I have a cylindrical tank welded the various points
I have dissected to 1/4 of cake my set including welds and you see dissected until here everything ok.... then I go into the study environment for the rendering imposed all the lights that I want then when it is ready to launch the rendering and as by magic I realize that in making it all right except the welds practically leaves them intact to 360 ° and I do not see them dissected ...: eek: from what can it succeed there is never
I forgot, I also tried to erase the welds that had been made with inv 2009 and to give it back with 2010 but nothing changes. .
thanks in advance to all
Hello, everyone. .
Sorry the question.. .
What do you mean, "I dissected"? ?
Did you make a cut together? or did you use the saw?? ? ?
Hello, mbt.
then I practically inserted a set in a new environment together, then with a sketch I made a cut from the top with extrusion to remove therefore I made a semisection of 1/4 of cake on my set that is nothing but a cylindrical reservoir also because it is the only way to show in make a semi-circular cut. ..cmq is all right except welds.... those remain in full on all the crank and are not rendered dissected. ...:confused:
How strange
