Danig
I have to make a ramp, small, which starts from a lower level and arrives 30cm higher.
the contours are curved but this is not the problem: I can't run it like I do.
I'll explain better. imposed as the lowest worktop, design the ramp, associate at the level 30cm higher and conclude the design.
the ramp goes out correctly if it wasn't for the fact that it is reversed!
How do I tell him that on the other hand he has to get up and that instead here he has to flatten himself? ?
already that there are, once solved, how to cut the floor that will overlap to the ramp? If I make size geometry it doesn't make me select the floor or the ramp. .
