PaoloColombani
It's not customary. probably something does not go into the process they have used for polishing.No. are tubes obtained by fold and then welded.
before polishing were extremely precise, after polishing they slightly deformed.
I saw the pdf scheme you attached. The idea seems good to me, I imagine you want to get a stagnant seal. to see the lip profile of the non-fatigue rings to believe that it can "strozzare" if not lubricated. with a similar profile maybe slightly increase the hardness of silicone resin could give results. But before looking for complex solutions I would try to walk the most trivial ways. I simply think that a silicone seal should be lubricated with paraffin (which provides a non-washable layer). How can you pose it? because the paraffin is medium solid (at room temperature) it can melt in epthane. Then the epic evaporates and leaves you a layer of paraffin. Alternatively, a ready detachment can be used to detach thermo-hardening resin from their moulds. other solution could be to apply paraffin fat, or petroleum (what you use to protect battery terminals).
