problem with annotation
  • Thread starter Thread starter bodi64
bodi64
problem :
with version 15 in opening annotation crashes and I have to "fall" the
3d modelling what with the 14 does not happen.
as operating system use xp sp2 and as graphics card geforce 6200
(which is the graphics card? ? ).
this pc is used only to display 3d files and not for
But why does 14 work and 15 not? ?
problem :
what you wrote really surprises me because I would not miss it, but I seem to have used for short periods version 15 even on a vetusto acermate travel 240 with about 725 mb of ram graphics card I don't know, but surely something totally unsuitable to the design cad,and even went with its times but went there I also did some handling. I think there is some problem in customization files that the pc loads at the time of annotation launch.
What are the files that charge?
(also drafting does not leave, but does not use it
I've never had a problem. )
that saw some files without knowing?
how do I know the files that are needed for loading the 2d?
thanks in advance
I believe that you would be of greater help a modeling installer, however I believe that the files that are loaded during the launch of annotation are in the folder c:\programs\cocreate\cocreate modeling 2007\personality\italian\sd_customize\annotation in which there are, if not erro, personalizations,le lisp etc. etc.
I would try to brutally empty the folder (having obviously done before a backup copy of the folder itself ) and then launch annotation to see what happens.
I would then look for the incriminated file by comparing the files contained in it with those contained in the analogue folder of the 2006 version. I don't know sincerely.
thanks in advance
"not part" is a bit generic, could you describe better what happens when you load annotation or me10?
problem :
try to erase all Winzozz printers..... .
by Mr President :
but then the window comes out.
"an error occurred . the application will be closed".
Please explain why I have to cancel the printers?
I am ignorant in these things
Hello and thank you
I tried, but annotation does not leave (it blocks halfway)
I tried to uninstall modelling and reinstall it but the
problem remains.
I'd like to know what's blocking the 2d.
relay previous message
erasing all printers, part of both annotations and
Drafting.
big andy, problem solved
Thank you:
