Patrikson
I have a problem with the arrangements in nx6 on a assembly built with assembly constraints.
more precisely, this assembly is made with array components (multiple series of 7) and an assembly constraints (distance) that drives me 2 positions; going on the practical:
closed (default) -> distance = 0mm
open -> distance = 64mm
without setting arrangements, manually changing the distance from 0 to 64mm, all components move according to logic.
if imposed the open and closed arrangement, the "father" component of the array moves, while all other components seem to lose their "binding association".
I don't understand how the logic of the "arrangements" command works... could you give me a hand?
Thank you!
Thank you!
