problem with catia v5 surfaces
  • Thread starter Thread starter jackpasq
jackpasq
Good evening to all
I am trying to reproduce the fuselage of a radiotelecontrolled helicopter but I have big problems with the surfaces, I am using caia v5. the reference lines for the construction I had to get them manually.... my problem is that I think I'm wrong the method by which I'm building these surfaces regardless of whether I can use the surface module.... I have attached
model 3d with the hope that someone will give me some straight, I've been banging my head for a few days but I haven't come out.. my idea was to create a half and then mirror it but I can't close the surfaces of the nose....the model is a little messed up I didn't care much about ordering the elements. . .
I now attach the file I didn't zip it....
from how it was modeled it is impossible to understand how it must be the muzzle.
it would be interesting to have an image of the final result.
what I feel to say is that the main mistake is to have used the command multi-section surfaces. I would have used the "sweep" command. I would have built the tracks and sections and then closed the top with the command "filling"
I thank you, but unfortunately I can't open the model maybe because you have verse 18 while I have the 17.....
I managed to open it with a version 18, the result seems good even if I had some tangency problem between the three patches.... Thank you.
Unfortunately I can no longer open it because I no longer have version 18 but only the 17....
