problem with center contenuti
  • Thread starter Thread starter citri
citri
Hello everyone
I just installed the 2011 version and already have the first problem (securely due to my... :frown: )
practically when I want to insert a part from the content center, I no longer see the library uni, I went to files -> projects -> configure library center content, and gives me the libraries anxious, din, feature, iso and jis in read-only and inventor other instead, is not available.
I assume that if I had installation cds I could try to restart it and see if there is a possibility to change it instead I have the "packages" downloaded from the autodesk site, someone knows how to proceed?
launch the setup, in the installation wizard select libraries, in the configuration select others and continue.
Thank you very much
I actually managed to do installation and within the projects also appears the others folder
