problem with code for selection of only visible blocks
  • Thread starter Thread starter yag
yag
Hello
I would like to write two rows of code to select through the xxxx function all visible blocks
But I don't understand why it doesn't work! the not working is equal to always select all the elements
here are the two lines of code that I use:
Code:
        filtertype(0) = 60
        filterdata(0) = 0
        sset.select acselectionsetall, , , filtertype, filterdata
Where am I wrong?
where do I find all the options available with filterdata and filtertype?
everything has to go on autocad 2007
Hello
Code:
        filtertype(0) = 60
        filterdata(0) = 0
Where am I wrong?
with what you wrote selects what is visible, without saying that you need blocks
to say "blocks" & "visible" you must write:
Code:
        filtertype(0) = 0:    filterdata(0) = "insert"
        filtertype(1) = 60:   filterdata(1) = 1
and dimension to 1 the two filtertype and filterdata vectors
note: in this way select the "block references" and not the "blocks". but I think it's what you need because the blocks are never visible in a drawing, while their inserts are
filtertype and filterdata options can be found in the "dxf reference" on the autodesk site ("http://usa.autodesk.com/adsk/servlet/item?siteid=123112&id=12272454&linkid=10809853") choose the correct autocad version and look at the first chapter
Code:
but must I put the : ?
I've tried it's not the same.
Before instruction sset.select insert a zoomextents not to exclude block inserts outside the current zoom window.
and eye I had mistakenly written filterdata(1)=1 while it must be =0 to select the visible.
If it's not qs then put your dwg and your dvb.
