cicciopiccio
Hello everyone,
when I use the matching command property between two objects placed on different layers I have problems. I try to explain: I have for example an object placed on a layer of red color and with thickness 0.35, and another object placed on a layer of blue color with default thickness. My intention is to use the co-ownership to apply the object properties placed on the red layer on that placed on the blue color layer, only that I want the color property to be applied and not that of the thickness, so I go into the settings and pull away the thickness check. But it doesn't work... how then to apply only some properties and others not? :smile:
