problem with command zoom esteso
  • Thread starter Thread starter flynight
flynight
Hi, I use autocad 2021 in English and can't insert the zoom extents command in the "standard toolbar". If I click on the dart next to the commands already present, then on "more commands" and scroll until I find the extended zoom command I should take it and drag it inside the toolbar. However, the command is blocked and I can't drag it. Is there another way to activate this command?
use the command which, in the upper left pane, expand the toolbars and standard branch, then in the bottom left pane, look for the zoom extensions command, drag it where you want to insert it.
bye
