problem with creating a project on server
  • Thread starter Thread starter ninfh
ninfh
Good morning
the company where I work has recently decided to use an external nas for project management, the passage of old works has gone up too many ferti on the field only that now when to create a new project directly on the server the path of the workgroup folder is considered not valid starting with \\ ....
would someone be so kind to tell me the correct procedure for creating a new project on a server outside the computer?
Thank you for reading this message
mapped in winzoz the folder that contains the various projects with a well-defined letter (which will all use).
at that point when you define the project he will find a path of the type
y:\container folder\projects
and should go
