problem with design assistant 2010
  • Thread starter Thread starter pagnotz
pagnotz
I am using design assistant (the old project manager...) to rename some parts of a set on which I am working, only that when I click on the column boxes "action", it does not give me the possibility to select "rename" (it is in grey), while they are active copy, replace and delete.
I've used it often in the past and I've never had this problem, someone has an idea what it can be due to?
no, it would be normal in that case that I don't make them change, but it also happens with normal parts within the project where I'm working. . .
I am working on old stuff made 2-3 years ago so with a previous version, but it was all migrated. However, something might have to do with it because if I open another set of another project in 2010, everything works regularly and I can also choose the rename command. .
try to open the axieme that from problems, save and say "yes all"
Sometimes it happened to me that automatic migration did not migrate everything....
It is also true that when you open design assistant you should report that there are files to migrate!
I solved the problem: practically the old parts were set in "project state" as "released", and this disabled the possibility to rename them. to do so you have to put back in the state "in progress" or "in wait". new discovery!
