problem with dialog boxes
  • Thread starter Thread starter rpor66
rpor66
in a lisp routine, I execute the command (command "_units") or (command "_linetype") with the result of having the command without its dialog.
Is there a way to activate it?
is there a method to recall the commands different from (command....) or (vl-cmdf ....) that allows the visualization of the dialogues?
thanks and greetings
Well if I remember well, (command "dduunits") shows you the dialogue while (command "-units") does not show the dialogue
for the linetype you should upload the dialogue, but I can't give you a hand
qaflags variable, set to 1 shows the dialog boxes in the commands started in lisp.
search and search at the end I found it:biggrin:.
bb
