problem with display window in plant 2d
  • Thread starter Thread starter merlo82
merlo82
Sorry, I'm banging to find this stupid solution, but I can't get out of it. .
the program is archicad 14
the problem is that in the insertion of the windows I can not see the side contours adjacent to the walls in a simple display in the plant.. .
I tried to change both windows and walls settings but nothing
I guess it's a stupid problem, but I just can't figure it out.
I tried to spulciate even in the forums but nothing.. .
Can you help me?
allego plant
hello to all is the first time I write Monday I have the official delivery and I am using archicad very few.... on the ground floor I put doors and windows and everything went well but on the upper floor when I insert the window asks me to indicate the point of half-try but the nn window appears or cmq remains hidden in the wall....how can I do to "bucare " the wall??? on the ground floor was doing it automatically... the same problem I had for the doors on the first floor but nn worries me because they are inside... but the windows I need...... thank you to those who will answer
you have to act on document views pattern options seen pattern
you can set them in how the window will appear in the plant and prospect, the advantage of archicad is that you can see the same things differently
