problem with export dxf
  • Thread starter Thread starter barby85
barby85
hi it has been for a couple of days that when I try to pass from a 2d drawing of proes to a dxf, in the latter I have only an image of the 2d drawing of proes; In fact, it creates an image, a logout file, a current file (such as settling) and the dxf within which there is only the link to the image of before. How come?
more than a month ago I did the same operation though it worked.I checked if the option in the conf file was pointing to the dxf_esport file and the path is correct.
Hello, waiting for your answer I tried to take a look at the configuration file of my colleague work but I found nothing unchanged compared to 2 months ago when the export worked me....how can I no longer export? I have to bring in dxf a structure but I can't for the problem that I explained in the previous post
I tried and tried,
but I can't happen in your situation,
You tried to export both a dxf and a dwg?
same behaviour?
What do you use?
to extreme evils, could you post design/model?
