problem with family tables in the axieme!
  • Thread starter Thread starter mali_fx
mali_fx
I made a family table of a set consisting of 3 components including, one (vite-tce), has variants and the other 2 no.
the other 2 components are guided by a sketch (made in the axieme) to which I have defined variants.
the problem is that when I open the variant together, the 2 components (guided by the sketch) remain tied to the odds of the generic and do not follow the variants defined by the sketch! I attach a file to make you understand better.
I'm 5 hours mad:
I thank everyone who will help me!
I've never seen the family tables used in "codesto" way and I don't know if they work.
I would have done more simply the variants of the two components and in the asm I would have attributed to the variants of together the specific variants of components.
another way that comes to mind could be the use of a skeleton with its variants and public geometry.
Thank you for the answer!
premitting that the family don't know them well (I'm trying to make a nice culture about it), the reason why I decided to do so is that the 2 components have the same variants in common and since I have to do so many similar asms, I wanted to find the right way in order to save as much time as possible.
