giancarlo75
I need to change a design that inside it has a set of grouped elements (I don't know if they are cells or groups or anything, I know that when they select a line takes me inside the whole block).
once the part to be changed with the command breaks element of the toolsbar groups, the problems that arise to me are two.
There is a line that represents a fence and is composed of a series of hyphens alternating with crucides.
the first problem is that once the design is decomposed the line is no longer whole, but each single indent or crucible is selected separately, as if it had been designed with certain patience piece by piece (which I doubt strongly).
the second problem is that wanting to recreate the line I am not among the available types of default in microstation that type of line, so unless you draw a piece at a time I don't know how to do.
