problem with mouse microsoft
  • Thread starter Thread starter enrimila
enrimila
Hello everyone
I installed solidworks 2010, until yesterday I used 2007 and as soon as I opened a working part, great surprise, the central wheel that I used usually for the rotation of the model and movements combined with the ctrl and shift keys, no longer works. What will happen to you? Is there a special approach? Mah!
thank you in advance to those who will give me help:eek:
no, the ws is the same and the drivers are ok, I soono realize that by clicking violently and moving the mouse, the rotation works but not always.
battery wireless mouse? Is this loaded?
Do you clean it occasionally? even if it does not have the "pallina" dirt and wear affect the good functioning/speed of response. open it, a nice blow and a spry spray for electrical contacts (also "type svitol" go well); to me they return as new.
Mar
with 2010 an option has been added that allows to assign to the mouse movements of the ad hoc commands (e.g. in the lower active line command, to the right extruded command and so on)
Now I don't remember if this is activated via the button or wheel, but you could also take a look at this function and check that the problems don't come from there...
activates with the right button and not with the central. control in the mouse drivers, the third key (wheel) must be set as "central button".
thanks guys problem solved with the suggestion of "re_solidworks". interesting the "mouse gestures" function that I found after the suggestion of "masses", clicking a mouse button of choice and making a quick move, you can combine commands that you use frequently, strong!! !
I thank everyone again for the support and suggestions.
enrico
