try to see if the paths are updated by hand in the options, otherwise try repairing the installation.Hi guys, since I took off the 2010 version on the pc to do some place, I found this problem!
Does anyone know how I can fix it without having to reinstall?
the path of solid 2011 is folder solidcorp\sw2011 but he goes to search where he was first in common with 2010. clearly I searched in the subfolder 2011 but there is the file "bednote.... "try to see if the paths are updated by hand in the options, otherwise try repairing the installation.
Hello mechanicalmg I just arrived! after I corrected the installation added me the missing file and then found the right item to change the bending notes!I'm gonna run the file, but the problem is that you have to change your property... file locations. then do you what is more comfortable but if you give yourself other mistakes you have to give back new paths.
