problem with part code in bom
gtsolid
ciao a tutti,1667459797817.pngin the screenshot you see that the pos.538 is correct, while the 537 reads the name of the configuration "l1=..." and not the name of the part.
looking at the information of the part I do not see fields out of place (it should use the field in line 7):1667459885967.pngDo you have any suggestions on how to make "d11740" appear, which is his real bom name?
probably reads the configuration name. check how the configuration properties of the part are set
