Stefano86TV
Hey, guys, I'm working on a little project. It is a model of my idea that I will make in wood ( laser cutting). so after drawing the tracks I take advantage of it to "mount" it in 3d and verify the correctness of the inks.
the other day I was working with autocad 2018. at some point I went in 3d mode to see details. some circumferences were not regular (so that autocad manages them so to save resources), so for lazy I entered 3-4 times below the command rigen. nothing has changed...but what is worse is that now I press "press and drag" begins to regenerate randomly (?) and becomes unusable since it slows down. after various and useless attempts I also tried to uninstall and reinstall the program, but the problem remains. It is a series of tracks and in some facades there are logos inside (exported by illustrator).
Is there a kind of diagnostic to understand what you're doing?
(on the hardware side there are no gaps)
Thank you!
Thank you!
