problem with rescue
  • Thread starter Thread starter xwebx
xwebx
Hello everyone,
I am a young pro-e designer.
I have a rescue problem with a new assembly name.
when I save, a screen appears to me (assembly save as a copy) with the list of components to be saved and next to some a red symbol appears with a x saying "references renemed model ____ ";
the possibility of modification is to rename the component (new name) or to reuse it(reuse).
to some appears (reused) and at the time when I try to rename them I appear the mex (new name action can not be performed for the model ___ because for incompatible status of their higher levels assemblies or/and lower components).
What can I do?
I thank you in advance for your valuable help.
hi, the red x in part to a model means that there are references in the model dependent on the axieme (e.g. you modeled some features using references in the environment together).
In this case, if you want to copy the aid, you are asked to copy also the parts related to it, to avoid conflict problems. instead the parts simply assembled, which therefore do not have references to the aid for their regeneration, you can reuse them.
thank you so much, but how do I save the parts related to them? always in the same screen or do I have to do it once in the assembly?
hi, on the same screen you must necessarily rename the parts marked by x, otherwise you cannot make the copy of the axieme.
to tell us, the rename in the screen means "Save by name", so all parts are copied and keep dependence on the new together.
but what doesn't make me rename on this screen as I save them?
1-make a backup of the aid in question in another caretlla.
2-open the backup and give the desired name.
3-place the renamed axieme in the workbook.
Hello everyone,
My name is Franciscan and I am a graduate in mechanical engineering. my problem is not related to the rescue but in carrying files from the version of proe wildefire 4 student version. How can I do that? Is there a programme that allows me to carry out export?
Thank you in advance.
Hello everyone,
export to which format ?
I should export files both on gambit and on fluent to study the phenomenon of cavitation. Thank you.
I don't know gambit and fluent but, dealing with analysis programs, I think they need discrete files.
so I think they accept "triangular" geometries like those of stl files.
It is enough to know what size they import and consequently export from pro/e.
