problem with retini "ar-conc" and "ar-sand"
  • Thread starter Thread starter Dario1982
Dario1982
Good morning, everyone. I write to you in the hope that someone can help me solve this problem: when I use a "ar-conc" or "ar-sand" retinal, sometimes it happens that if I reopen the design, it displays these retinals as "solids". and it is not a matter of regeneration, because, while doing "regenerate", nothing changes first, but then also printing me as solid. I noticed that by doing some operations on the retino, for example "setting" or "cancella", and then going back with "annulla", the display goes in place. But maybe reopening it the next time the problem is resumed.. what is due how can I do? Thank you so much!
Here.. the retino is the only one that is there, the one under the layer "0_hatch" which should be a "ar-conc"
I solved: it was a problem of a system variable: hpmaxlines.. the set value initially was too low, I set it to the maximum (10.000.000) and now the nets are displayed correctly! thanks the same!
