problem with scale
jim78b
I have acad mech 2013 .in the layout I made 2 viewports with scale 1:30 and 1:50. at each quota I have put scale annotative and added the scale 1.30 and 1.50 . It happens that in a viewport some quotas show 2 values in different sizes . and then I can not select or delete them ... I think I have done everything right or not?
Do you use mechanical with quotas? you are throwing away the potential of the program.. .
make the windows in model space, which I think you haven't done, and exploit the power commands as quotas, text symbols and so on.
the mode is simple, already written in other threads but I do not want to look for them:
create a window in model space with amscarea
give the scale factor
the confirmations and vien automatically created a window in layout of the same size as that present in the model and with its scale factor
all the odds you will insert in the window into the model space will take the size of its scale factor
http://www.cad3d.it/forum1/threads/...ione-sbagliata?p=374976&viewfull=1#post374976http://www.cad3d.it/forum1/threads/...con-mechanical?p=394595&viewfull=1#post394595
but the text ...discussed by the confusion in the model space I make it annotative or provides him?
I read your post ok. but the odds I put in the model?
and I wrote it
He handles the text.
if you then decide to change the scale factor of the window just select all entities and these are adapted.
Because I enjoy making a video. I'll take the camera. ciack turns:bekle:
View attachment area di scala.zip
ok seen the video thank you so much. But do you know if I make a 1:50 scale arrow and then I want to scale it doesn't?
the leader in fact does not work and you have to copy the properties of the quota. there should be dedicated directors, look under the noted menu
ah here in fact .the director of autocad mech.ma does not make me the contours /frames around the text. and I think you can not .
