problem with scheda grafica per autocad r12 in ms dos
  • Thread starter Thread starter jim78b
jim78b
I know I'm a nostalgic but I had in my hands autocad 12, I installed the cad in a virtual machine except that the problem is the graphics card, I can't find what goes well then I just give it 5
You don't have many choices ... so you can't do anything but choose the vga, so in theory you would try to choose the resolution 1084x768 if I don't remember bad, then the cards had floppys with dedicated optimization drivers, I think you should also see the lines a bit seated if not erro, for the plotter which driver?? or what did you configure?
I had instead autocad architecture 10 - 386 if not erro and arten 90a.
A lot of water passed under the bridges.
Ma non ca'avete proprio un biiiiiip da farme!: d: d
Neither do you.
then for the uninformed for me autocad 10 dos, it was the first software portabile from me realized.
It was enough to install autocad 10 with a generic vga card, a generic mouse, and a generic hp, all copy it in a 1.44 floppy, and with dongleykey you could work everywhere.
Obviously with all the problems and dangers of floppy, but it worked.
Then I press that I don't know what I'm going through! Since I'm emulating with virtual box the dos!
when installing the only one that goes and the ibm driver I see that charge but do not appear the writings!virtual box should emulate a vga s3
