problem with solid edge viewer
  • Thread starter Thread starter blackmagik82
blackmagik82
Hello everyone, I have a problem to solve, I hope you can help me.
When I make a 3d design with solid edge sometimes I happen to hide objects that I do not want to be shown, but then opening the same design but with the solid edge viewer I appear all the objects also those I had previously hidden.
Does anyone know how to help me?
Are there other viewers who show me only what I have effeously shown in original 3d design? or are there any other methods I can use?
I press that I can't make pictures of piece 3d or other things like that because ilp ezzo must be seen as I see it with solid edge and therefore be able to be ruoted or put in view as you normally do with the viewer, only though without that sin of having to see also the hidden objects.
I hope to have been sufficiently clear!:smile:
I don't know, you can export to step or parasolid with the option "export only displayed", and then send to your interlocutor this file (the viewer if it seems to me load the parasolid files without problems). this assuming that your purpose is to prevent your interlocutor from going too far into your project! :smile:
If what you have to do is simply save a visualization status, try using configurations, but not if the viewer supports them.
You should save the configurations of what you see and what you don't see and then call them back from the viewer.
How do I save the configuration? Do I have to go to view configuration and save it from them? the configuration file then where do I take it? and the viewer as the amount?
Sorry all these questions but this kind of operation I never did
