problem with solidity multiselezione
  • Thread starter Thread starter mf92
mf92
Hello, everyone. I have a little trouble to draw a longheron of a wing. I created the two profiles, initial and final (which are different as the wing is tapered). I intended to create the longherone with "solid multisection" however catia does not make me select the two profiles.
what could be the reason for you?
from what I can see from the image you posted
sketches, or a sketch contains points that are not
in construction mode. . .
this could be the reason that prevents you
to make the loft-
you have to return to the sketch and set geometry
construction for the...
in any case for more clarifications you should attach the file. .
so with only image it is easy enough to shoot out target
to the
to make the loft-
to the
I thank you very much for the answer, I solved and took it with points not in construction mode!
