problem with "structural element"
  • Thread starter Thread starter PiegatoreSolidworks
PiegatoreSolidworks
on the home computer I am testing sw2012 and it happened to me that creating a simple piece made of 3 inclined and welded tubulars I create in the list only a single piece not selectable individually when I go to create the cart.. .
what may be the wrong setting or problem?
in the main tree ("features manager), under the heading "elements list", try to click and see how many details you have created, possibly, try right button and "upon".
if you do not solve the problem in this way there might be something in the table you insert in the drawing.
in the tree I appear 1 element and not 3 as on the 2011 version. same procedure results different.. .
You'll understand yourself... :smile:
I am a artichoke, indeed the king of artichokes! certain that putting yourself to do the tests at one at night serves little and the results you see after how you read from my question of the post... ! ! ! ! ! ! !
Thank you for your help.
p.s. but what is it to create a single structural element?
I try... perhaps in the case of a dish as a profile you can create a shaped sheet, perhaps by connecting it later in the corners.
Well, let's let the vegetables go. I also spent sleepless nights
for things I now do with closed eyes and hands tied behind my back:finger:
with regard to the utility, they are many, you can simplify the table of simple structures without having to select each individual body, or for "curve" structures (such as parapet handrails) where the various curves are shortened in a single structural element.
If I find some time, I'll put you a simple file.
good morning, thanks for quick answers and availability!
view attached pictures, note the simplified list and complete list.. .
among other things also design times have a downfall of not little account, if you try to reproduce a similar railing you can find yourself:
If you plan by joining the bodies, when you go to make cuts, taking the attached file, for the handrails you will have to select only the body that represents the complete handrail.
same applies to horizontal tubes that go to drill the plant. . we say that both functions are halved and therefore times, and not by little.
llink for the swx file
http://www.mediafire.com/?6w1bef0rlodfku6
the option relative to the curved segments there was already believe since 2010, the novelty concerns the edge joints between lines.
about the utility, they are multiple, you can for example simplify the table of simple structures without having to select each individual body.
I felt bad... dictated by the fact that yesterday I modified a railing similar to that placed, drawn by a colleague, who did not have the active option, now instead in case of a similar structure (with other straight sections) the option "new" is activated.
However for clarity, it is worth what I have already written and quoted above.
honestly on the transformation option in lam. I had not thought about it, of
I usually hardly twist a project, I usually have clear ideas on how to build, my works are quite simple and rarely repeat.
Thank you, King, I learned another one!
