problem with sweep
  • Thread starter Thread starter ARberto
ARberto
hello to all colleagues.
I attached an image whose sweep is giving me a lot of trouble.
Some of you would be nice to let me know where I'm wrong in the command sequence.
it is a tray tendingly elliptical, derived from an extrusion, then stripped, then rayed, then excavated.
I entered the guide section and the director section.
problem solved. I think ptc should do so to shorten the sequence of commands to get the set result in the best way and time possible. said this, I create I like it as slender as compared to the other software I use.
You should explain where the problem is.
to build the geometry relative to the image you post does not need the sweep.
thanks for the courteous attention.View attachment 41477
Tell me what you need in this sweep tank?
for me he did a solid extrusion, a stripping, a radiation and then used a sweep to remove the material inside. even if it is not clear to me if the requirement was a wall of constant thickness.
simpler the solution with surface extrusion and feature thickness, or solid extrusion and then shell function.
as the ultimate solid extrusion alternative, external surface offset that is used as a cutting knife for the feature of solidification with removal.
