com_che
Hello everyone, I have a problem with a wall. use revit 2009, I have to make a wall that has external bricks, inside plaster white, inside in property element, structure-modification, imposed the outer layers finish1(4) laterizio1 thickness 10 cm, interior finish 4 plaster white thickness 2 cm.
I make the render and I find myself applying the bricks on both sides, you know where I'm wrong? I searched in the forums and also in some guides, but from what I saw the procedure is correct.
Thank you very much
Thank you very much
