problem
  • Thread starter Thread starter cncgsita
cncgsita
as from title I can not convert and develop the sheet in question. . .
to the eye I would say the problem lies in the edge on the short side
Shouldn't open the same, but in visualization mode?
and where this fashion would be
you cannot open files created with later versions.
at most you can view it with edrawing.
I happened to open a part in the past made with a later version,
He opened it to me but without a tree,
I could only see "the shape"
Here we go. http://help.solidworks.com/2016/italian/solidworks/sldworks/c_previous_release_interoperability.htm
if opened in the previous release, later release files are displayed in read-only mode and reduced functionality. featuremanager contains limited data.
in fact the interoperability of the versions is supported only between consecutive releases. ad esempio, non sarà possibile aprire file solidworks 2014 in solidworks 2012 service pack 5.
I attach the steps of the piece, one with the profile of the sheet to be folded and the other with the solid emptied to be converted into sheet metal so also who does not have
My version can look at it.
Thank you all!
as working on an undevelopable step is a casino I started to create directly the slide with me sheet letting it be the program to manage the discharges.
the measurements are rounded but the geometry seems to me to be fairly faithfulView attachment scivolo.zip
I downloaded the file.
I honestly don't understand why you let the "cut" function be supported by a sketch with errors. It also gives me a mistake about this sketch (scratch 3) of not identifying the plan.
