problema assieme- think design
  • Thread starter Thread starter gemini179
gemini179
Hello everyone,
in closing a think group file, a message appeared (which I did not read) and I clicked directly on save. once I reopen the file I realized that it is no longer possible to make any changes and as soon as I try to create a sketch in the working environment gives me an error message. I ask for your help as the file in question must be sent to production...I attach the file hoping for your resolution.
hi, I opened the file with 2015.2 and I have your own problems, as well as the lack of external references and solid positioning, which however should not decisively affect the functionality of the axieme. from my personal experience, files saved after a critical system error, are no longer functional nor reliable as those saved regularly. check if, by chance, automatic backups are not active. that you have the active maintenance contract or not, it would not be a bad idea to contact the dpt directly to inform them about the ineffectiveness of their post-error rescue. if you show serious people, and especially professional, you should almost certainly give assistance.
thanks polymar, the problem is also that I can't save it as .stp to import it into other software
Of course, I'll be very helpful. ..unfortunately the file is damaged,do not extract the .rar
hi, I downloaded the archive previously loaded on mega and used the winrar 5.30 to extract it. I then opened it with td 2015.2: I confirm that everything works perfectly :finger:
Thank you very much, it was the version of winrar that didn't go
hello guys any of you still think design by chance?
you made the same request on three different discussions, not so the forum works.
First of all the question must be clear, it must respect the regulation (there is no illegal material treated), and it must be made in a discussion inherent in the request if there is otherwise a new consensus should be created.
