viper
hello to all, I have a huge problem simulating the surface of a d32 ball mill with a 3 axle milling machine.
I'll explain better.
I have two guidelines, the main one that is the center and the secondary one that is the ball tangence.
If I do a sweep it generates a edge and the nn puperficie turns out to have constant r16 radius.
If I do a swept same thing....
I also tried to make a sweep using two tracks through which to pass the girth of d32 and imposing the variable section, but still doing a bending analysis does not maintain the constant radius!!! and therefore the cam (mastercam 10) nn manages to work the surface.
Can anyone give me a tip? ? ?
Thanks
Thanks
