problema fori iso
  • Thread starter Thread starter gaslinger
gaslinger
hi to all excuses I am new, I approached me recently to creo3.0 and I have problems with the configurations, I have the student version, and when they select between the list of holes iso for example a m8 assigns him a diameter of 0.26 I try to give ok and tells me "unsuccessful regeneration" ... it is not surprising... it is as if he did not have the quotations iso.
Can anyone help me?
Hello gaslinger,
I am not the most expert of proes in the forum, (and often I understand one thing for another.....), but so to nose that 0.26 stinks me so much inches..... (0.26*25.4=6.6). I would first try to verify how the measuring units are set.... I would then do other tests on new parts by recreating an iso hole m8 or similar.... if it does not change anything.... I would be curious to see that table iso.hol (look for the file in the comupter and open it with a common text editor) uploads you.... lets you know, the case is curious. I don't know how to tell you more and I can't do any tests, except inches.
