problema form tools
  • Thread starter Thread starter marcofranz
marcofranz
Good evening,
Today I did not pass the cswpa sheet metal certification because in half questions there was to use a training command and I could not apply it.
I had followed the training tutorial at the university and on the computers I managed to run it correctly, here on the home computer, with the student version, after uploading the sldprt file to the sheetmetal tool folder, if I drag it to screen on the piece to be unformed I don't get out any shaping window.
Where's the problem?
you tried to use the molding tools already present in solidworks. If they work it means your punch doesn't work and you're wrong to do it, otherwise it could be something else, and at this point it would be better to contact the assistance.
I don’t have any tools, at least I don’t think I see any tools, so much so that it tells me to install the toolboxes.
I have the student version, I don't know if it affects.
the piece to use as formtool I didn’t do it but I took it from the tutorial and uploaded it following the steps
Unfortunately in the student version of solidworks you can't activate toolbox, so who is doing you do the course or lend you the license or you can't do the certificate of that module.
forms tools have nothing to do with the toolbox.
are library functions, so they are simple customizable and creeable functions from the individual user; are located in the library folder where the functions are placed to perform tab and seeger locations.
I doubt that the student version has inhibited the creation of library functions.
personal note:
These certifications leave the time they find and in fact serve only to say that you know how to use the commands (even on this I would have to laugh), but not that you know how to manage the program.
the problem raised in the discussion shows that you do not even know what tools you are using (toolbox/book function).
know how to sweep, a loft with seventeen sections, an intersection or a quadrimensional surface in 20 minutes is not learning in software
per le librerie di solidworks
I can't find any design library.
Before opening a post I tried.
I wrote to the dassult and told me to do the same steps that I did but obviously it doesn't work, I don't find the libraries.
I find that file if I apply that search.
Anyway searching the internet I found why I didn't see the design library, as it was in the programdata folder that is hidden.
I added this link to the solidworks library, now I have everything, but in any case it does not apply to me in case I draw a piece of those on a sheet
I solved, practically after moving the car5tella design library from programdata on the visible sw folder, I managed to find the design library on sw but as said gave me the problem stain, solved simply by popping the box "shaping tools folder" from right button on the forming tools folder from sw
