agoz
hello to all I am a designer who has just started using inventor 2012... I found a probblema regarding the mirror of a 3d sketch that I can't fix...I created within a part (.ipt) a 3d sketch with lots of odds and constraints, then I opened a new assembly (.iam) is I imported the part by inserting the frames then I made a mirror of everything and until here everything well... the probblema is that once mirrored, if published the odds of the initial sketch the changes are not made correctly in the mirrored part. . .
you can tell me if it's an inventor's bond or I'm wrong.. .
thanks in advance
thanks in advance
