problema nell'importare un file ipt in ansys workbench
  • Thread starter Thread starter anto94
anto94
Hello. I am new in the forum, I apologize if I have wrong section. I have a problem when amounting an ipt file (inventor 2018) on ansys workbench 19.2. I did the plugin for inventor in cad configuration manager 19.2. I can open files that contain only surfaces and solids. If I amount a pattern for lines I can't see them. I can't figure out where the problem is, I popped up in line options as in the attached image. Thank you in advance for the answer.
