problema preselection highlighting
  • Thread starter Thread starter lotus77
lotus77
Bye. I have this kind of problem... installing the wf2 on a laptop (the same version with settings identical to what I currently use without problems on my laptop) I realized that although in the startup configuration is set (sent) the preselection highlighting, this does not work! Do you have suggestions? I think it's something inherent to the PC video card (invidia) because everything else is perfectly working and as I said before identical to what I use.
I confirm that it may depend on the video card.
for confirmation you may use your configuration files on the other machine and if the problem remains no further explanations.
in fact I have already made this test but I have not had positive answers... Well... I'll try to see if any set of the video card goes into conflict with that option otherwise I just don't have to leave it like this...
Thanks anyway.
I found the solution: properties on launch icon proe > compatibility > check "disable desktop composition"
restarted proe wf2 and preselection highlighting now works! !
