problematic file verification
  • Thread starter Thread starter gil
gil
I got a pretty simple file, but it has the ability to lock my autocad.
I open the file, I work a bit, but then the consumption of the ram sketches up, although not exhausting it, autocad freezes. waiting for a few seconds, but continuing also simpler using the pan command and zoom over time the problem worsens until autocad remains nailed and I must force the resource management lock.
then I exploded everything, then brought everything on a single layer and copied on a new file. this is usually decisive for this kind of problem. but this time not, it is a crazy file, small, but incredibly pissed off.
Surely my outstretched autocad does not help, but want to ask you to do if you notice problems and possibly what may be due.
p.
seems that the free viewer dwg true view 2018 does not have the same problems
p.
to me with autocad 2023 it goes very quiet apart a few clicks every now and then. probably export from another program. in case of a "overkill" and a "purge" to eliminate overlaps and clean unused elements.
possibly in options, display card, decrease the detail value for curves, segments etc.
Try this, I think it's a lot more manageable now.
I just made a copy of all entities, created a new design and on this I did glue.
the dwg has not lost in size kb but is much more manageable to video than the original file.
It's possible that some layers bother.
beyond that I do not have big problems of manipulation (I have the variable viewris to 1000),
a slight block anyway there is (perhaps a second) and I noticed that the part that bothers is the bottom left grave and the drain of the pool. this because they have overlapping lines and curves; using the command merge and selecting all the drawing (respecting the command 3/4 times) select it greatly improvesImmagine.webp
in fact the version of tristus is much more usable, then completely removened the objects signaled by massivonweizen, seems completely in place.
I had already tried to explode everything, but I didn't think some objects could be so "tenacious". Thank you all.
the fact that you don't give the problems I've seen from what it can depend on? certain limited hardware does not help, but with the problem viewer there were no problems. maybe even the vetocity of my autocad contributes?
to me it was annoyingly to small shots when I rotated the view. Yes, there are many lines one above the other, however their number did not seem excessive, such as to affect the fluidity in the rotation of the views, so I left them.
once glued all units on a new blank design the layers that were not active at the time of copying disappeared.
so I think the problem can depend on some layers.
Yes, the last beach remains. to me it has happened many times and has always solved the problems. of course in the new design it is necessary to recreate the layers disappeared, but it is avoided to remake everything.
cmq I spoke too soon. the file continues to be problematic. the problem does not occur with the free viewer. Therefore I am led to think that autocad 2004 contributes decisively to the problem even if perhaps the hardware puts us on its own.
I tried to use the can and embalmism qcad, in demo version. same use of ram, same blocks seen with autocad. However autocad crashes, perhaps due to its vetocity, qcad does not and manages to continue working, despite the problems just mentioned.
I don't know your hardware, but I'm telling you, it doesn't give me any trouble. but not the lightened version of tristus, your own.
made pan and continuous cycle zoom, to strain it I put it in realistic view, I made 3d gogò orbits.
No slowdown, let alone a crash.
all while I keep open another file with about 30 thousand entities, including a tide of dynamic blocks.
What hardware do you have? I an i7-11700k with 16gb at 3200 and a vetusta rx470.
Hello.
opened your file with other programs, in one the thickness of the lines was thick with excessive slowness in zoom, pan, etc.; brought to zero the thickness of all lines the file became much more manageable. of course many graphic values have been lost, however ...
I can't believe
there are repeated lines, but the total amount of the drawing is not excessive. It's just a plant with lines. probably in your archives you have drawings that contain many more entities but you can handle well.
I think it's a layer problem.
I would try to put everything on a level after which to recreate the layers, maybe rename them. But it's better to do this test on the file I've attached before.
I also gave the design a problem, while the lightened file was fine.
I repeat, it is strange because, even if there are repeated lines, the number of entities contained in that design is not excessive. I think your hardware and your autocad can handle such a file without problems.
