problememi audit manager tr7
Conte91
I am following the directions to use the reviosion manager directly from the siemens site..
and I'm following the directions, but I'm not doing what I owe. .
provided that in the tutorial you see that the version used is the st5 while I am using a st7..
First of all, he tells me to put my document, in this case a set, in release.
done
as second thing tells me to use the "revision manager assistant" saying that it is in the tool tab............. I'm already standing
I attach screen of my command bar.. .madonne.webpCan someone tell me where to find the command?
if instead I access from files / manage /revision
doesn't let me select the command. .
to tell you all the document in question "is not handled" and I would choose the option (as from tutorial) "copy a file"
the purpose was in fact to copy the axieme with its components in another folder so that I can perform my changes,
coming from solidworks what I would need is the equivalent of the pack & go...
Okay.
I answer myself:
I had to open the file to explore resources with dx key "open in revision manager"
and continue with the instructions of the tutorial
Thanks :cool:
if you are looking for something similar to the pack & go look here:
http://community.plm.automation.siemens.com/t5/solid-edge-forum/pacedge-free-pack-and-go-for-solid-edge/m-p/288303/highlight/true#m7514in any case learning to use revision managers is always useful.
I actually found myself well with revision managers and I got what I wanted. .
But this option is also tempting!
but really you have to do all the tutorial to download it? !
Thank you very much be on edge!
I didn't look at it, I assumed there was a download link along with the advertisement.
This is part of a series of tutorials to learn to program with solid edge.
if I find the direct link the place otherwise I unload the sources and fill them.
I tried to download something but I quit because I found .piz files and too many files that first impact had nothing to do with it.. in the future I will test also pacedge.
Now I need another question.
using as mentioned above revision manager (to manage files by making a copy of a set and copying together with it all that it contains under a new directory and modifying the names here and the of what interests me) I am caught in a mistake.
every time he does a check on the "where used" of the files I tell him to process (the files I want to copy)
at first sincerely I wondered why.. I thought that beyond everything if you, if, you have to copy me a set in a new folder.. this set (copyed and renamed) refers to all copied files.. to you of the documents in which my copied files are used you don't have to import a bump. Right?
I remember that the functions of revision managers are:
copy files what I used
Revision of files
move a file
replace a file
Looking for a set for a file or string (? )
ok open and closed this parentheses.. I found myself that, in a copyed and renamed set I decided to rename everything that was under (it was a welded frame)
result: after processing for twenty minutes.. he renamed the files below the main axieme.. where these details were inserted.
to be clear I take the axieme to containing 123 with revision manager.. copio file a becomes b and 123 I decide to make them become b1 b2 b3... result in the assieme c that contained 2.. now I find mounted b2.. :mad:
Now I would just like to know: I was stupid that I simply had to release the aid before doing this procedure ? (as the siemens guidelines say for revision managers) or is there any other?
thanks for the attention.
Unfortunately there is little material on the net on if and the revision manager is often an unknown thing.
It is a powerful application but at first you bang your head.
I am still at the beginning, before doing special things with rm, I make a copy of the folder. I don't know.
hi to all I downloaded the file packedge.piz I opened it by renamed the extension in .zip and I extracted the files , so far all right ... but as soon as I entered the .asm file to create the pack the program got stuck without sending messages... I think it is not compatible with our version if (st4) ...
for now I continue to use revision managers, the only abnormal operation we found when, in the copy, there are already duplicated files: If the same detail mounts in 2 different subaxes and I try to copy them simultaneously, made the first revision managers plant when duplicating the second finds the component of before.. .
Staff online
TEST BANNER QUI.
