problemi context
  • Thread starter Thread starter jackpasq
jackpasq
Good evening
I hope someone can help me, I'm doing a job and I have different context problems, the problem is that I can't identify what exactly are the elements that create the conflict.Premetto that within my study there are electrical wiring and parts made with the surfaces, one part represents a metallic stocking and another represents a protective thermo-shrinkling stocking.... is there a command that tells me what are the binding elements, which create the context? How can I delete contexts, maybe external reference? Should I isolate them? I'm freaking out with these contexts.... .
I'm sorry you're freaking out. . .
as I had already told you, to work in context you need to pay attention to the bonds that you create between the parties, otherwise you may run into errors that make you lose more time to make up than to copy the part inside the catpart: it is necessary to use it only if you master well as how caia manages the links between the parts, the saved etc.
working in context creates external reference. advise you on what to do without seeing what problems are (you talk about elements that create conflicts, but don't even mention the error message that appears: difficult to understand what you are facing) giving you some generic suggestion just risks getting worse.
It is possible that you have worked on the project with an unsuitable method, but I repeat it difficult to assess and intervene without seeing.
